Re: Can I start my H with the driveshaft coupler disconnecte
Posted by rustyfarmall on April 16, 2011 at 06:30:15 from (209.152.78.140):
In Reply to: Can I start my H with the driveshaft coupler disconnected?? posted by Faster346 on April 16, 2011 at 05:25:54:
That is not a good idea. If you must start the engine, you should completely remove that driveshaft first. Also, do NOT depress the clutch pedal. Doing so will allow the clutch disc to become mis-aligned with crankshaft pilot bearing, and you will never get the driveshaft back in there
