Re: Cub value and what to look for...
Posted by holmesw on April 16, 2011 at 07:37:46 from (67.54.176.38):
In Reply to: Cub value and what to look for... posted by grayrider on April 15, 2011 at 13:49:53:
If the owner would allow it, a compression test would be a wise thing. I have heard that these cubs cannot be overbored and sleeved when the cylinger walls go bad. About the most you can do is overbore what you can, and put in larger rings.
