Re: Super A No Power
Posted by Justin on July 27, 2000 at 20:51:49 from (216.161.98.155):
In Reply to: Super A No Power posted by Stan on July 27, 2000 at 19:48:19:
I would suggest removing the plugs for inspection, and at the same time doing a compression test.. After checking the compression, post the results here.. If you have one or more cylinder that reads far below the others, then you have an engine problem that could be caused by worn rings, burt valve, blown head gasket, etc.. If everything checks out, then I would play with the timing..
Post A Followup
: Re: Re: Super A No Power
