Re: Re: Re: Re: H Countershaft Seal
Posted by justin on July 27, 2000 at 22:15:11 from (216.161.98.218):
In Reply to: Re: Re: Re: H Countershaft Seal posted by RB on July 27, 2000 at 19:16:48:
You won't need to remove the belly pump, just the coupling that connects the countershaft to the pump drive.. All you have to do is remove two cotter pins and move two retainer bushings to the center of the shaft, and it will come right out.. Sometimes the drive nut on the countershaft is hard to remove.. inspect the nut for wear, and if it looks excessively worn, you may need to find a new one or find a speedy sleeve for it..
Post A Followup
: Re: Re: Re: Re: Re: H Countershaft Seal
