Re: 400 head studs
Posted by soybeanjoe on April 16, 2011 at 22:24:12 from (66.213.171.108):
In Reply to: 400 head studs posted by bugspot on April 16, 2011 at 18:41:07:
I have always been told that the studs need to be al the way down with no threads showing. Some are blind holes & others go into the water jackets. I run a tap down the threads to make sure the threads are clean & straight then make sure the holes are clean with nothing in them Oil or bits of crud in the blind holes will keep the studs from going all the way down so I use air to blow them out. I like to use a thin coating PermaTex #2 on the stud threads. Make sure none of the Permatex gets on the bottom of the studs as that can hold them up as well.
I just put a new head gasket on my SMTA & found several studs with threads showing. It had been getting water in the oil. Head gasket was good & machine shop found no cracks in the head. After removing the studs & doing as described above I was able to seat the studs all the way down.
I have heard others say it doesn't matter on the threads but the above procedure was recomended to me by a couple older IH mechanics.
