Re: F-20 crankshaft
Posted by BruceS. on April 17, 2011 at 04:14:49 from (76.15.41.252):
In Reply to: F-20 crankshaft posted by Evan Mellott on April 16, 2011 at 11:10:55:
My two F20's have both had crankshafts removed, and new main bearings installed. IMHO, the only way to do this is to remove the block from the frame rails and have the crankshaft pressed out. That way you're not damaging anything, and if you do replace the mains, everything will be in proper depth and alignment. I would try to find bearings with 11 balls in them. There are new ones out there, but they only have 7 balls.
