Posted by realolman on April 17, 2011 at 05:21:39 from (70.16.88.212):
Does anyone have experience with a good tool or method to get zerk fittings to take grease?
If I pump the grease gun hard enough, the fittings will blow out (pressed in ) so the grease fitting itself is open... it's the joint that won't take the grease. I've seen a thing that you're supposed to fill with oil and put on the fitting and smack with a hammer to force the oil into the joint. That seems like it would work because the force of the hammer blow would also hold in the zerk fitting, but I don't think the location of all the joints would allow access to such a thing. It seems that having a flexible hose would defeat the purpose, because I can already blow out the fitting with a grease gun.
I have several joints like this , and I'd like to avoid taking them apart if possible... any suggestions would be appreciated... thanks
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
