Re: engine oil for cub
Posted by Denny ('60 Lo-Boy) on April 17, 2011 at 05:56:29 from (71.50.222.251):
In Reply to: engine oil for cub posted by CharlieNJ on April 17, 2011 at 04:44:11:
Use what ever your oil of choice is for any other equipment you have. Today's oils are far superior to what was available then. I use 10w30 or 30w.
For the hydraulic system, Case/IH Hy-Tran is the preferred choice but I use Tractor Supply Universal hydraulic fluid. Does a good job.
In the transmission use 90w gear oil. It only takes 3 1/2 PINTS. If overfilled it will just leak out the seals and coat the brakes.
