Re: Cub 154 idles but won't run
Posted by Dellbertt on April 17, 2011 at 16:49:48 from (209.172.22.243):
In Reply to: Cub 154 idles but won't run posted by Tonym1994 on April 17, 2011 at 14:38:49:
Jim is right on, except for the inline filter(there should be one there):)
It's about 50/50 on this site and others as to their use.
Irregardless, something is blocking fuel, whether from the tank (which I suspect) or somewhere in the carb. You might take the main jet out of the carb and blow it and the fitting out. My cub did the same thing, it was a piece of crud in the main jet.
Dell
