Re: 1952 farmall super a
Posted by Hendrik on April 18, 2011 at 02:44:29 from (193.176.225.6):
In Reply to: 1952 farmall super a posted by gidtex on April 17, 2011 at 09:46:34:
There is a felt seal AND a seal with a rubber lip.(The seal with a rubber lip is peculiar in the sense that the seal is mounted on the shaft and the lip faces outward. The lip rides on a wear ring (sort of sleeve) which is pressed into the hub of the wheel.)
I got mine from Carter and Gruenewald.
HTH, Hendrik
