Re: H rear wheel bolts
Posted by Yooper Farmall on April 18, 2011 at 06:55:22 from (141.210.112.16):
In Reply to: H rear wheel bolts posted by Doug Flory on April 15, 2011 at 12:54:54:
I received these 12 bolts, 12 thin nuts and 12 regular nuts in the mail Friday. Bill with shipping came to $57, much better than $300 from Case-IH
It looks like he used a 4 1/2 inch square head bolt with about an inch of thread and used a die and cut more threads. Looks like the die was a little dull because the threads on the first inch look fine, the threads the rest of the way look very rough, I ran a nut down it, didn"t go very smoothly by hand. I"m going to buy another die and try to clean them up a bit, although I"m sure they would work just fine, and for a $250 savings I can handle some rough threads.
