Re: Farmall 460 overheating hydraulic oil
Posted by charles todd on April 18, 2011 at 10:32:34 from (155.130.107.41):
In Reply to: Farmall 460 overheating hydraulic oil posted by Matt1983 on April 17, 2011 at 18:58:45:
You could also have worn rings on the lift cylinder(by-passing) and the position control is fighting to maintain set position. Then the oil gets too hot to work correctly and lets the load drop.
I need to tear into my 504 3 point because it "hiccups" and gets worse as the oil warms up. Any internal leakage will cause heat. When I'm mowing with my 504 in the summer, my oil temp has gotten to 200 degrees. I know it is because the rings are leaking, cuasing heat.
I may be off base here, but it sounds good. 8)
CT
