Re: Choke on my C to make it run
Posted by Bill in NJ on April 18, 2011 at 15:32:32 from (4.248.92.131):
In Reply to: Choke on my C to make it run posted by Eric P on April 18, 2011 at 15:00:12:
Sounds like it is either starving for fuel or your gas is stale. Check lines for clogging and/or drain and add fresh gas.
