Posted by AG in IN on April 18, 2011 at 16:32:32 from (67.236.85.111):
In Reply to: Tisco Carb Kit posted by J.L. Every on April 18, 2011 at 06:32:19:
The last Tisco tune-up kit I bought for an IH distributor on an M I had to bend/twist the points quite a bit to get them to align squarely. Might have been just the kit I bought, I don't know. I've have had better luck with Tisco kits for D-R distributors.
The last A&I kit I bought the rotor was junk. You could slide the contact piece around about 1/4 inch.
The last "genuine" CIH ignition parts I bought the cap woudn't even come close to fitting properly. They must have changed suppliers or something about a year ago.
All imported condensers seem to be of questionable quality. Some work fine, some make your points look like you welded on them after 5 hours, some just quit. I try to reuse my old condensers if the points look fairly decent for the hours that are on them.
Lately I've been buying NAPA/Echlin ignition parts. Pricey, but they fit and hold up well. I have also had good luck with Standard and Blue Point ignition parts in the past, too.
Years ago, nearby TSC or QFF stores stocked "Standardized" ignition parts in a bubble pack. The other had "Sorensen" ignition parts. Both were good bang for your buck.
The holes in some of the aftermarket bowl gaskets are usually a bit off. Make sure you use good packing for the main fuel adjustment screw if it isn't in the kit. When you get the carb apart, make sure you shake your float to be sure it doesn't have a hole in it. Check for throttle shaft bushing wear too.
Some folks curse the rubber-tipped needle seats, but I think they're in the CIH kits, too. The rubber-tipped ones stick once in a while and the old style steel ones can seep.
Always check dimensions of the main nozzle before swapping it out if it's in the kit. I can't speak for Tisco's kits, but A&I's nozzles are sometimes wrong. Compare all shafts, butterflies, etc., to your old ones.
Don't toss any old parts until you are happy with the way your tractor runs with the new parts in the carb.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
