Re: Converting Farmall C to 12 Volt Electronic ignition.
Posted by Owen Aaland on April 18, 2011 at 17:01:41 from (216.47.33.82):
In Reply to: Converting Farmall C to 12 Volt Electronic ignition. posted by Joe Nielson on April 18, 2011 at 11:31:56:
While the 12SI series alternators will work fine I believe what Bob M meant to say was 10SI. Both alternators are the same physical size and the same connections. The 12SI is a little heavier duty unit designed with better cooling to handle higher amperage. Higher output is not needed for the C and the 10SI is more readily available.
