Re: 560 hydraulics problems
Posted by pete 23 on April 18, 2011 at 19:24:16 from (74.44.100.190):
In Reply to: 560 hydraulics problems posted by Kyle Curtiss on April 18, 2011 at 18:35:50:
First check the single to double action settings on the aux valves. One may be turned too far bending or breaking the roll pin and that will cause system to stay on demand. The 560 is not really a true open center valve system as there is no flow through aux valves when in neutral, the flow from the pump is diverted to reservoir through the regulator valve ( unloading valve). This valve is controlled by a screened orfice under the cover of reg valve. If plugged or peened undersized it will cause your system to stay on demand , fluid going over relief valve portion of regulator valve assembly. Clean or replace orfice if plugged. More information on other posts previous to this one.
