IH 1000 Loader
Posted by Doug Kieta on April 18, 2011 at 19:32:34 from (76.1.103.220):
I am currently trying to get a IH1000 loader in shape to mount on my SA. I am trying to remove the pin where the loader boom mounts to the subframe directly in front of the hydraulic valve.
Should this pin be able to be removed from either direction? It looks to me like the previous owner welded a washer on the inboard side so that the pin can only be removed by driving it from left to right when viewing it from the operators seat. There is an angled grease fitting on the inboard side which leaves very little room for the pin to hammer on.
Any tips on removal of this pin will be appreciated. It looks to me like the first thing I should do is cut the weld and remove the washer so I can drive the pin to the right.
I would sure appreciate a close up picture of this connection on a working loader.
Thanks for the help.
