Posted by Bob M on April 19, 2011 at 06:51:11 from (67.240.171.41):
In Reply to: Farmall H PTO posted by David G on April 19, 2011 at 05:58:09:
Slow turning when disengaged is caused by viscous drag of the gear lube "dragging" the PTO shaft around. (With the engine shut down manually turn the PTO - you will feel the viscous drag.)
Now if the transmission has SAE #140 gear oil in it, draining, flushing and refilling with lighter 85W-90 gear oil MIGHT stop the shaft turning. But it also might not....
Aside from the safety issue, a drifting PTO shaft causes no other problems. However never grab the shaft on ANY tractor while the engine is running!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
