Re: Farmall 706 regulator
Posted by DeltaRed on April 19, 2011 at 07:50:36 from (97.124.219.62):
In Reply to: Farmall 706 regulator posted by Scottsphere on April 19, 2011 at 07:44:31:
The NAPA # will not be the same as the IH #.I would use it and not worry.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
