Re: Farmall B 8 volt Battery
Posted by Galen Cornwell on July 28, 2000 at 14:04:17 from (216.89.172.163):
In Reply to: Farmall B 8 volt Battery posted by Dan McGuire on July 28, 2000 at 07:21:57:
A 6 volt battery charger will not work!!! It will not charge the battery, as the voltage output of the charger is to low. Do not use a 12 volt charger, as it will over charge and cause damage to the battery.
Consulate a good battery shop, for a 4 cell battery charger.
If you stay with a 4 cell, 8 volt battery, adjust the output of your generator up as high as possilbe, but no higher then a total output voltage of 9.48 volts.
If you have additional question, please let me know.
Post A Followup
: Re: Re: Farmall B 8 volt Battery
