Posted by farmallhal on April 19, 2011 at 15:01:55 from (76.4.174.81):
In Reply to: Hand Cranking Super C posted by Albo5000 on April 18, 2011 at 17:54:54:
When I first bought my Super C the whole charging system was just a mess and I hand cranked it for about the first year. It is very simple but look real close at the photos Jim Becker posted and note your thrumb SHOULD NOT be around the handle. My SC was very easy to start and usually only required a crank or two before it started. Some people crank one pull with the switch off to prime the engine and the next pull with the switch on to start on second pull. Key is having it running very well and timed correctly. The end of the crankshaft where the crank is inserted is shaped in a manner that it pushes the crank out of the tractor a little bit to disengage it so it doesn't keep spinning around when tractor starts. Start with the crank in the 6 o'clock position and give a quick pull up on the crank and don't try and spin the crank as that is where trouble begins and is not needed. Being on the end of a spinning crank is not the place to show off your manly atributes, Hal.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
