Re: Converting Farmall C to 12 Volt Electronic ignition.
Posted by Owen Aaland on April 19, 2011 at 15:58:36 from (216.47.34.111):
In Reply to: Converting Farmall C to 12 Volt Electronic ignition. posted by Tony_Idaho on April 18, 2011 at 11:31:56:
There is very little mention of using a 12SI alternators on this board so I was pretty sure you meant 10SI.
If you just want to upgrade to an alternator from the generator you do not necessarily need to go to 12 volt. A 10SI alternator is easily converted to 6 volts by just changing the regulator. You would also need to switch the battery to negative ground.
