Re: 2c-f21 2 point mower pittman bearing
Posted by Lmack on April 19, 2011 at 18:18:45 from (98.66.236.35):
In Reply to: 2c-f21 2 point mower pittman bearing posted by j.m.jackson on April 19, 2011 at 10:39:33:
The 2C prefix must mean "Two Point Hitch, C, and the F21 is the mower designation. I have a 2C mower and the drive and parts appear to be the same as for the other pitman mowers. Unless someone knows different, I would try the bearing for the other mowers that are listed. You might check to see if the same bearing is listed for all the pitman mowers for which parts are listed. It will take a little time, but if all the bearings have the same part number you should have your answer.
