Re: 2c-f21 2 point mower pittman bearing
Posted by Jim Becker on April 19, 2011 at 19:21:35 from (173.57.144.251):
In Reply to: 2c-f21 2 point mower pittman bearing posted by j.m.jackson on April 19, 2011 at 10:39:33:
The first 2 means farmall 200.
The C means Farmall (Super) C.
The F means Fast-Hitch
The 21 is the model number of the basic mower.
If it has a plain bearing pitman, the bushing is M 22 212.
If it has a ball bearing pitman (likely), the bearing is ST 314.
The ball bearing will also have felt washers front and back, M 32 933 (1-39/64 ID x 2 OD x 1/4 thick).
Between the bearing and each felt washer is a retainer M 32 779.
These numbers are probably the same as you found on any other pitman type mower you looked at.
