Re: Carter carb on Super C
Posted by Ron-MO on April 20, 2011 at 04:59:20 from (173.186.164.74):
In Reply to: Re: Carter carb on Super C posted by rustyfarmall on April 20, 2011 at 04:41:08:
I have one on my C, which had a leaky float. The floats have not been available for quite some time, but I repaired mine about 10 yrs ago. I was able to find the leaky place (likely a leaky solder joint), I cleaned it up well, opened up the hole a little larger drained and dried it then resoldered it. No problems so far with since. Hopefully all you need is the kit, but floats can be repaired.
