Re: C-Fast idle problems solved, new exhaust nipple next
Posted by rustyfarmall on April 20, 2011 at 08:42:36 from (209.152.78.140):
In Reply to: C-Fast idle problems solved, new exhaust nipple next posted by MK in Ontario on April 20, 2011 at 08:13:46:
I would not use a torch to cut it out because you stand the chance of doing damage to the manifold. Cut the old pipe flush with the manifold using a hacksaw, and then using just the hacksaw blade, cut a vertical slot in the remaining portion of the pipe, but do not cut into the manifold. You should then be able to place a punch or chisel against the top of the pipe, strike it with a hammer and begin folding the pipe inward until you can get a prying tool in between the pipe and manifold to finish the job. If you can get a good portion of it folded inward, you should be able to start un-screwing the pipe from the manifold. It might be fairly easy, but more likely it will fight you every step of the way.
