Re: C-Fast idle problems solved, new exhaust nipple next
Posted by mkirsch on April 20, 2011 at 11:35:35 from (64.80.110.75):
In Reply to: C-Fast idle problems solved, new exhaust nipple next posted by MK in Ontario on April 20, 2011 at 08:13:46:
You may not even need to do any cutting inside the threaded area.
Leave the pipe a bit "proud" of the top of the manifold. 1/2" should be plenty.
Take a large cold chisel, and with the cutting edge vertical, tap it into the protruding pipe.
Usually the pipe is corroded enough that it will collapse and peel away from the threads without damaging the manifold.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
