Posted by The Dukester on April 20, 2011 at 15:19:14 from (209.86.226.19):
In Reply to: M wheels on an H posted by Bob Purinton on April 20, 2011 at 14:28:43:
If the H's engine is stock, good 11-38 (12.4-38) tires on stock rims and wheels are plenty big enough to harness all the power and put it to the ground that the engine can deliver. You can put wider rims on the stock H wheel centers if you've got some sort of a strong engine built up in the H. How could you tell the wheels on the H were M wheels anyway? Did they have some sort of shims around the axle? Or was it just because the tires were the same size as the tires on the M?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
