If no bolsters are available, as a last resort---use a center punch to make dimples around the worn seat where the bearing or race sit on. Then use red Loctite when assembling the package & allow to set up before using. If the nut is worn in the threads, get a new nut & tighten to where needed & then weld the nut to the spindle at 2 places. You can grind the welds off later if service is needed.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
