Re: H hydro oil check
Posted by rustyfarmall on April 21, 2011 at 06:14:02 from (209.152.78.140):
In Reply to: H hydro oil check posted by Robin Hood on April 20, 2011 at 15:57:45:
There is a drain plug in the bottom of the belly pump. It holds 6 quarts.
Take a good look at your air filter oil cup. You will see it is impossible to fill the inner part without filling the outer part at the same time. If you CANNOT see it, you need to thoroughly clean that oil cup.
