Re: cub clutch won't release fully
Posted by Mt.Man on April 21, 2011 at 07:02:15 from (74.212.60.138):
In Reply to: cub clutch won't release fully posted by tomga on April 21, 2011 at 05:27:45:
The best way to insure you have the exact 1/8" clearance between the fingers and the throw-out bearing is to adjust it in the tractor throuh the inspection hole on bottom. This is not easy but it can and should be done. Then adjust your 1" of free play with the adjustment on the clutch pedal. I'm talking about if your tractor has a graphite throw-out bearing. All fingers have to be exact spacing because this type of graphite bearing does not turn.
