Re: Water pump on C?
Posted by Don R of MN on April 21, 2011 at 07:35:31 from (204.248.127.93):
In Reply to: Water pump on C? posted by Frank Caldwell on April 21, 2011 at 04:01:59:
A way to tell if you have thru Super C it should have disc brakes. Because it wouldn't be the first time the wrong decals were used. Just my 2 cents worth.
