Re: Setting Regulator voltage on a Farmall 706
Posted by Owen Aaland on April 21, 2011 at 07:43:32 from (216.47.33.6):
In Reply to: Setting Regulator voltage on a Farmall 706 posted by DanR on April 21, 2011 at 07:25:18:
It takes a little while for the regulator to operating temperature, longer for the external regulator than the internal ones. Regulators are designed to allow a higher voltage when cold than they do when warmed up. Run the tractor for at least a half hour before deciding that any adjustment is necessary.
If it is a new regulator and is out of adjustment I would have it replaces rather than trying to readjust it.
