Re: Offset Shifter - Janicholson, any post with pictures ?
Posted by sflem849 on April 21, 2011 at 09:34:09 from (69.197.84.78):
In Reply to: Offset Shifter - Janicholson, any post with pictures ? posted by couv on April 21, 2011 at 04:58:53:
I've seen Jim recommend a stick and a pocket knife before. Use the stick as a mock up and then weld and grind your shifter accordingly.
The H one can't be too different than any other letter series model. All their transmissions are built using the same style. You can always easily redo the project if it is too big or too small.
