Re: H PTO seal
Posted by Michael Soldan on April 21, 2011 at 16:29:54 from (24.235.36.230):
In Reply to: H PTO seal posted by David G on April 21, 2011 at 15:54:01:
No,you don't need to drain oil,park the tractor on a barn bank or ditchbank so the front is lower than the rear end. Use some chisels and a punch to collapse the seal away from its housing and pick it out,may be in pieces,clean and put a film of grease on the shaft,slide the new seal on and carefully tap it into place. The new seal won't be as wide as the original steel and felt seal. It will go fairly well for you,be patient!
