Good chance the thermostat is not working or has been removed.
However in cooler weather an idling M is tough to bring to operating temp, even with a good thermostat installed. There's a substantial bypass passage cast into the thermostat housing around the thermostat. Enough coolant flows through the bypass to keep the engine from warming fully even with a working thermostat in place.
Try working the engine hard for 10 - 15 minutes and see if it comes up to temperature.
Or if you want to test your new temp gage, remove the bulb from the head and stick it in a pan of boiling water. The gage hand should move to the top end of the "run" range
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
