It's as simple as unbolting the wide front end and bolting up the narrow. Narrow front ends are very simple, and just bolt to the plate where your pitman arm is bolted to now.
C's and Super C's both use the same front end. The tractors are very common, and people generally want to convert to wide front, so there should be plenty of narrow front ends available.
You can poke around online, but I suggest hunting down a local tractor salvage yard within 1-2 hours drive. It's likely you'll need parts again at some point, and having a good semi-local source in your pocket only makes sense.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
