Re: 674 pro's and cons
Posted by Wi-Ed on April 22, 2011 at 06:05:51 from (216.41.196.241):
In Reply to: Re: 674 pro's and cons posted by mike van on April 22, 2011 at 02:41:45:
The parking brake will continue to work fine as long as you remember to release it. I had a 574 and the parking brake always worked fine. When I sold it I pointed out the problem to the new owner. Needless to say he took out the parking brake the first day.
