Didn't some of the IH built engines have one ot two of the bores that were not a standard size? And I think those bores were marked with a mark of some kind stamped into the top of the block right next to the non-standard bore? If that is what it is, the standard issue, over-the-counter sleeve and piston kit will not fit. You may need to visit Case-IH to get the correct sleeve.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
