Re: SPARK PLUG FOR M
Posted by Phil Auten (TX) on July 28, 2000 at 20:19:59 from (206.175.72.226):
In Reply to: SPARK PLUG FOR M posted by JIM on July 28, 2000 at 13:14:22:
Jim,
I'm using D21-Y Champions in my '49 M and they've given good service for the year or so they've been installed. The D17-Y Champion's that were in it before fouled out pretty quickly, even with the carb adjusted correctly. Bama Binder has a point about not going too hot on a tractor that gets worked hard, but mine just gets used to mow bar ditches and pasture and does most of that in 4th gear.
Phil
Post A Followup
: Re: Re: SPARK PLUG FOR M
