Neat pictures, but you might ought to get new moldboards; they can't do a good job like that.
As to the sucking oil, using light oil will cause it to do that. Make sure you are using the same oil has in the crankcase, hopefully SAE 30.
About the fuel problem, you need to make sure there is fuel to the carburetor. If not, you may have rust in the tank. If there is fuel at the carb, you should take it off and clean it real good (easy to do) and make sure the main jet is not clogged. Good luck (and nice pics) SF
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
