Re: Cracked? Useable?
Posted by rhtx55 on April 22, 2011 at 17:19:04 from (207.119.44.250):
In Reply to: Cracked? Useable? posted by caseman-d on April 22, 2011 at 16:37:15:
Sorry to be the one with such bad news, if it were mine I would tear it back down, strip the block, have it tanked, and then magnafluxed to check for any more cracks, once they have all the cracks identified and possibly fixed, the bores can be machined for oversize sleeves to use your present pistons, or you can go with bigger sleeves & matching pistons to match if you wanted to bump up the HP a bit.
A salvage block to replace it with would be another option, but you would need to check it for cracks first also, unfortunately, either way, you are back to square one.
