Re: Farmall Cub serial numbers
Posted by gene bender on April 22, 2011 at 18:38:38 from (207.177.56.53):
In Reply to: Farmall Cub serial numbers posted by Colin Caissie on April 22, 2011 at 16:49:54:
Yes that would be the best way to go. You dont have anyidea if it has been bored and the only way to find out is remove head and pan then you can do the measurements. Same way with the bearings looking at the numbers will tell you if the crank has been ground. Mite need over size bearings both rod and main.
