I think you're on the right track (shift rail not moving far enough to engage 5th). And another possible cause for this is a worn shift lever.
You might try pulling the lever (knock out the pivot pin at the base tower then lift out the lever). Then take a LARGE screwdriver, stick it in the notch in the right most shifter rail and use it to lever the rail as forward as far as it will go. (It might help to rock the tractor a bit as you work the shift lever).
If it now catches 5th gear, check the shift lever tip and pivot parts for excessive wear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
