Posted by Janicholson on April 22, 2011 at 19:34:20 from (67.72.98.45):
In Reply to: Cracked? Useable? posted by caseman-d on April 22, 2011 at 16:37:15:
Cracks like those can and do cause water leaks down between the sleeve and the block casting into the oil pan. The situation is now a decision between getting a replacement block, or having it bored to receive a repair sleeve, then rebored to accept the normal dry sleeve, or thinner sleeves to make it displace the same as a Super M. If it is already using the Thin sleeves, no issue doing one hole, but it does require tear down for machine work, as noted in the other post. A very modest sanding of the cast bore is OK, honing is almost never done as the bores are often looser than desired when refit with sleeves. Sleeves need to be chilled and block warmed , then usually driven in with a block of wood after slipping in 1/2 to 2/3 of the way pretty easily. A different block might be a better option in this case. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
