Re: mounted plow
Posted by George Rausch on April 23, 2011 at 05:20:32 from (64.85.214.32):
In Reply to: mounted plow posted by rod in nebraska on April 20, 2011 at 18:15:59:
JIm Becker - Back in the day when I had to "poor-boy" it all I could afford was an old H, an old used JD plow and a new 3-point hitch from a local manufacturer. It took me all summer trying to plow the gardern, yanking that H over to the left, swaying the plow hard to the left. I had to lay on the gruond behind that mess and study it all summer long, and I finally realized how plows were designed; they are supposed to cut a perfect right-angle furrow, in all 3 axes. I adjusted the top-link so it cut perfectly level, and didn't dive in or pull up, I adjusted both bottoms so they cut equal depths, and I invented a turn-buckle "brace" to haul the assembly exactly 14" over to the right, 14" from the right tire, and hold it there. Works perfectly, and I see how it is all designed.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
