Re: 1952 FARMALL H QUIT RUNNING
Posted by old on April 23, 2011 at 10:57:20 from (4.245.14.71):
In Reply to: 1952 FARMALL H QUIT RUNNING posted by STEPHEN FAILLA on April 23, 2011 at 10:35:37:
#1 please get rid of the cap lock no one like to be yelled at.
#2 trouble shoot do not throw parts at the problem that will cause more problems.
#3 That said make sure you have the points set right at 0.025 if memory serves me right. Then check that you have a blue/white spark that will jump a 1/4 inch gap. If you have a good spark at ALL plugs then go to a fuel problem check. Pull the drain plug out of the bottom of the carb and make sure you have a good steady flow there for 5 minutes. Catch the fuel so as to make sure it is not full of water and rust/dirt. If no flow work back to the tank to find the problem
