dont worry about the caps . Look at the problem this way it was running then stopped now common sense will say it ran out of fuel the plugs wires and so forth didnt all go bad at once so check the fuel see if its comes out the carb when the drain plug on the bottom is removed. That would be the most likely thing to check.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
