Posted by Heat Houser on April 23, 2011 at 15:02:38 from (69.66.35.73):
In Reply to: 460 front seal posted by kjrtractors on April 23, 2011 at 09:34:01:
If it is the front crankshaft seal, it is just as easy to pull the front bolster assy. Two radiator hoses, two power steering lines, sheet metal, and the bolts holding it to the side rails. The steering shaft should slip off of the power steering unit as you pull it forward.
Just did this on my 560 to get at the steering sleeve. The front crank pully is then easy to service.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
