Re: H bolster
Posted by Nebraska Cowman on April 24, 2011 at 07:31:42 from (66.252.115.12):
In Reply to: H bolster posted by David G on April 24, 2011 at 07:25:34:
You probably could. But it's gonna make it hard to handle and I don't see what you would gain. Removing the shaft is not going to upset anything you did last year.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
